I have a WS-26-500-DC powering a Baicells Nova 233 Gen 2. As you'll see in this image, the POE port is showing >150 Watts for some reason. The Netonix's Firmware Version is 1.5.5.
I have the exact same setup at another tower, with very similar power cable lengths, and it's showing a normal 15 Watts. That one has FW Version 1.5.2.
Any suggestion on what to check? I already tried rebooting the Netonix. Is it a Baicells problem? Could it be cosmetic? The ports aren't even supposed to be able to do more than 72W on 48VH.
Port shows 150 Watts while powering Baicells eNB
Re: Port shows 150 Watts while powering Baicells eNB
Probably the current sensor is damaged.
- jorgenekah
- Has thanked: 4 times
I have exactly the same issue in 5 netonix switches, some ports are now showing 39watts for a ubiquiti nanostation, how can that be? can someone from netonix help us to fix this issue? when you say the current sensor is damage it means that port is really consuming that wattage or it is just a bad reading?
