New root
quadra
Has thanked: 3 times
New root
Sun Mar 22, 2020 4:58 pm
Hello
since the last update I often have these root messages ...
Mar 22 21:09:04 STP: MSTI0: New root on port 3, root path cost is 40010, root bridge id is 32768.CC-2D-E0-E3-43-8A
Mar 22 21:10:51 STP: MSTI0: New root on port 3, root path cost is 40010, root bridge id is 32768.CC-2D-E0-E3-43-8A
what do he mean? :yikes:
I have nano ac connect in POE 24V on these ports and sometimes it cuts the communication !!
I have no error on the port
what to do ?? :willy:
Thank you
Re: New root
Sun Mar 22, 2020 5:56 pm
Are you intentionally using spanning tree? If not, disable it.
quadra
Re: New root
Mon Mar 23, 2020 5:55 am
what the spanning tree ?
and how to turn it off ? :shock:
Re: New root
Mon Mar 23, 2020 7:36 am
STP = Spanning Tree Protocol
On the switch it is set per port on the STP tab. You will have to look for the setting on the radio.
quadra
Re: New root
Mon Mar 23, 2020 9:14 am
Ok :agree:
