Authenticated SMTP Failing if password contains Equal Sign
aaron@futuretk.com
Thu Dec 19, 2019 12:41 pm
I'm getting an error message when trying to send email alerts from the switch if the authenticated SMTP password contains an equal sign. I have not done extensive testing to see if I can identify any other characters that cause this. I tested this on switch with 1.5.0 through 1.5.4 firmware versions.
Thank you
-Aaron Clark
Been thanked: 208 times
Re: Authenticated SMTP Failing if password contains Equal Si
Thu Dec 19, 2019 1:11 pm
As it turns out this is apparently a bug with the ssmtp package itself. I'll dig around to try and find a patch and push it to the next release.
Btw affected characters are ":" and "=", so for now it would be best to remove these characters from your smtp password.
aaron@futuretk.com
Tue Dec 24, 2019 12:34 pm
Thanks Stephen
