Firmware v1.1.6 bugs and comments
Tue Mar 31, 2015 7:44 pm
Please post comments and bugs for v1.1.6 in this thread.
FIXES
- fixed problem changing password where you sometimes had to change the password TWICE sometimes for it to take.
****There are no other changes to v1.1.6 over v1.1.5
KNOWN BUGS
- If using DHCP and you change the Default/Management VLAN ID after the switch gets an address is does not get a new address.
- Not all CLI commands are present.
- In the CLI some voltages are reported incorrectly with the "sh status" command
- In the CLI not all command are present to configure VLANs
