TFTP Backup Issue
krakrenterprises
Been thanked: 7 times
TFTP Backup Issue
Wed Nov 27, 2019 11:33 am
I have created a cloud TFTP server and tested sending files to it.
However, when the auto backup attempts to send the file it says "timeout" in the log. On the TFTP server, the file has been created, but contains no data.
What should I check to correct this?
Re: TFTP Backup Issue
Wed Nov 27, 2019 9:33 pm
You could first try to upload trough any TFTP client from your computer on the same network to be sure the TFTP server is fonctionnal.
Is the TFTP server behind NAT with port foward ? If so, TFTP is not NAT friendly but you could try TFTP helper on your router if it support it.
Been thanked: 158 times
Wed Nov 27, 2019 11:17 pm
I had Stephen make up a recovery software tool that does all the work.....he is polishing it up & we will release it early next week.
krakrenterprises
Fri Nov 29, 2019 2:39 pm
I can TFTP from my local machine to the remote server without issue. The server is public IP, no NAT.
The Netonix gives a generic timeout error in the log, but the file is created on the server, but is blank inside.
