LAG issues with Cisco ASR
mayheart
Has thanked: 48 times
Been thanked: 60 times
Tue Aug 20, 2019 10:53 am
Hi there,
I'm having issues with a LAG setup between a Cisco ASR920 and a Netonix. Just wondering if anyone has seen anything similar?
On the Netonix what I have configured: port 1&2 key 0, LACP-A, Slow, 32768. I've tried switching to LACP-P & static as well, no change.
On Cisco:
Code: Select all
interface Port-channel5
description ETHERCHANNEL TO TOWER NETONIX
 mtu 9000
 no ip address
 no negotiation auto
 no keepalive
[vlans here]
interface GigabitEthernet0/0/4
 description LINK TO NETONIX - PORT 1
 mtu 9000
 no ip address
 media-type auto-select
 negotiation auto
 channel-group 5 mode active
interface GigabitEthernet0/0/5
 description SECOND LINK TO NETONIX - PORT 2
 mtu 9000
 no ip address
 negotiation auto
Logs on the Cisco switch:
Code: Select all
100844: Aug 20 10:41:51.430 EDT: GigabitEthernet0/0/5 taken out of port-channel5
100845: Aug 20 10:41:51.438 EDT: GigabitEthernet0/0/5 added as member-2 to port-channel5
100846: Aug 20 10:42:48.795 EDT: GigabitEthernet0/0/4 taken out of port-channel5
100847: Aug 20 10:42:48.886 EDT: GigabitEthernet0/0/4 added as member-2 to port-channel5
100848: Aug 20 10:43:19.120 EDT: GigabitEthernet0/0/5 taken out of port-channel5
100849: Aug 20 10:43:19.135 EDT: GigabitEthernet0/0/5 added as member-2 to port-channel5
100850: Aug 20 10:44:13.276 EDT: GigabitEthernet0/0/4 taken out of port-channel5
100851: Aug 20 10:44:13.468 EDT: GigabitEthernet0/0/4 added as member-2 to port-channel5
No noteworthy logs on the Netonix, I don't see the flapping in the logs. Not sure what here really to check.
Re: LAG issues with Cisco ASR
Tue Aug 20, 2019 12:52 pm
I was unaware that Cisco supported LACP LAGs in their routers, they do in their switches.
I use STATIC LAGs between my Cisco 2951 and my Netonix for that reason.
I know you can put in certain 4 port EHWIC expansion switch cards and then establish LACP on the switch card from the router but never tried it.
mayheart
Tue Aug 20, 2019 2:48 pm
Yeah the ASR901/920 series supports LACP. They're really switch/router combos meant for outdoor telecom sites and hardened for harsh environments.
https://www.cisco.com/c/en/us/td/docs/r ... 01010.html
I'll try setting both for static and see if that makes a difference.
