Hi guys,
I've been scratching my head for a couple of months as to why four of my WS-12-250-DC switches keep rebooting every 2-3 weeks with firmware v1.5.1. Looks to be a memory leak, as the memory usage slowly creeps up until the switches reboot.
These specific switches are at two different sites (two switches per site - WS-26-DC was not available at the time of deploying) with each two switches connected by Direct Attach Cable (FiberStore SFPP-PC005 to be exact).
To clarify, I know the firmware I was running is now an older version and there have been a couple of memory leak fixes lately, so last night I've upgraded the firmware to v.1.5.3 at one of the sites to see if the issues magically go away - time will tell. Also, none of my other Netonix switches (none of which use DA cables) have this issue.
Now the reason I think this must be an SFP/DAC issue (I've determined it's not power related, and the high memory usage over time confirms this) is because both switches would reboot at more or less the same time as each other - perhaps even at exactly the same time (hard to know for sure). I can't think of anything else at either site which could cause this.
Physically accessing either of these sites to remove the DAC and replace with ethernet is a bit out of the way; although I do plan to visit one of the sites at some time in the near future. But even still, ports are limited, and also I'd rather not have to replace them with WS-26-DC if I can help it.
Does this sound like I'm on the right track in regards to this issue? Chris/support, if I sent you one of these DA cables, do you think you could try it out and see if you can replicate the issue?
Thanks!
Suspected Memory Leak with DAC (SFP)
StrataNet - Member
- Has thanked: 5 times
- Been thanked: 4 times
Re: Suspected Memory Leak with DAC (SFP)
To add, I've skimmed over the post here, but I don't think it's related: viewtopic.php?f=17&t=4868&hilit=sfp+memory+leak
I always use DAC in between switch and never saw any issues.
I use both Mikrotik FS DAC cable.
- Been thanked: 210 times
The most recent memory leak that was fixed was related to SNMP. The symptoms you're mentioning now sounds very similar to the issue that was reported here. If your switches are being monitored via SNMP then it's possible that the patch in 1.5.3 will fix the issue.
StrataNet - Member
Hi Stephen (and mike99),
Thanks for your quick replies. Ok great; I'll wait and see if the v1.5.3 patch will fix this issue and will advise.
Cheers!
Cheers!
Users browsing this forum: Google [Bot] and 24 guests
