LAG and ERPS
dgerlach@disquom.de
LAG and ERPS
Tue Aug 06, 2019 8:32 am
ERPS without LAG works fine, but with LAG we have Problems. How is the config with LAG? Do you have a short Example? THX
Been thanked: 208 times
Re: LAG and ERPS
Tue Aug 06, 2019 12:50 pm
Do you mind describing what the issue's are?
dgerlach@disquom.de
Re: LAG and ERPS
Tue Aug 06, 2019 12:57 pm
A lag has two are more ports in a Group, in ERPS Setting i only can define 1 east or West Port. What i miss is to define the lag Group for east or West Port.
Re: LAG and ERPS
Tue Aug 06, 2019 1:02 pm
Ahh I see, yes that would be a problem. I will test this out and either let you know a work-around or work on a patch to try and get it onto a new release.
dgerlach@disquom.de
Re: LAG and ERPS
Tue Aug 06, 2019 4:10 pm
Thx
