Config corrupted?
bmwake
Config corrupted?
Mon Aug 05, 2019 2:38 am
We have around 25 - 30 WS-8-150-DC out in the field, and seem to be getting fairly regular (probably every six weeks or so) issues. We lose all remote management to the switch, and when site staff restart it, it appears to have lost configuration - POE doesn't come up, management not available, etc.
Getting them back to my office and using the console port, it appears to start up normally, but when the boot process looks to be finished and I hit enter, I get the following:
Jan 1 00:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Jan 1 00:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Jan 1 00:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Jan 1 00:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Jan 1 00:00:04 kernel: 0x00fc0000Jan 1 00:00:04 Jan 1 00:00:04 Jan 1 00:00:04 Jan 1 00:00:04 kernel: mini_fo: using base directory: /
Jan 1 00:00:04 kernel: mini_fo: using storage directory: /jffs
vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
BusyBox v1.19.4 (2018-06-07 14:48:31 EDT) built-in shell (ash)
Segmentation fault
Segmentation fault
Segmentation fault
i2c /dev entries driver
Segmentation fault
Segmentation fault
The seg fault message then just keeps repeating over and over. Hardware appears to be fine, factory reset and reconfiguration sets it back on its way nicely.
Any suggestions on cause/solution?
Re: Config corrupted?
Mon Aug 05, 2019 3:16 pm
What version of firmware are you running?
Always use the latest when having an issue to make sure it is still happening.
If your switches are running older versions there were security holes discovered and fixed in later versions.
Also if you switches are accessible to the public then use the Access Control list. Actually it is always a GOOD IDEA to use the access control list to limit who can access the switch.
bmwake
Mon Aug 05, 2019 10:54 pm
Initially 1.4.8, as I've worked on them they've gone up to 1.5.0 and some to 1.5.2. Latest three have gone to 1.5.3.
Just rather tough to get approval to bill for the time to upgrade all at once.
They're all on a management VLAN which does have limited access already.
Tue Aug 06, 2019 12:43 pm
Well v1.4.8 definitely has security holes that allowed a hacker to corrupt the flash but not take control or change anything but still VERY BAD.
This was not a hole in our code but the web service [ lighttpd ] we use to run the UI.
https://en.wikipedia.org/wiki/Lighttpd
A factory default will clear it then upgrade
Access control list only helps if the switch is on a public IP not a NAT as the switch will always see the packets coming from the NAT address regardless
Personally I only put my infrastructure on non rout able IP outside my network then use Access Control list to prevent people from inside my net from attempting to access.
Only way outside can get to it would be to hack one of our devices in the allowed IP ranges and spring board into device.lighttpd
bmwake
Wed Aug 07, 2019 1:28 am
Quick check, I can't find any still running 1.4.8, all 1.5.0 as minimum (from memory, did get to go through all for a major version number change)
My repair process is console to verify it's this same thing, factory, upgrade to whatever's current, and reconfigure
Had been wondering if it might be temperature, but most recent failure's replacement has been sitting around 40 - 45 max
