Sorry if this has been up before, new to switch, can the switches power cycle the POE much like the Ubiquiti Tough Switches do.
We want to migrate away from tough switches and this feature is very useful.
If not can it be added as a future feature .
POE Power cycle
- airfast
Re: POE Power cycle
First I moved your post from the PICTURES post to a more appropriate venue.
Define power cycle port. There is the Tools/Watchdog TAB that can power cycle a port based on a time and or ping loss.
There is the little gear on the right of the port row on the Status and Ports TABs that allows you to Bounce the port which is a power cycle of the POE.
Maybe define what you want but as far as I know you can do more with power cycling our ports with Netonix WISP Switch then you can with the UBNT ToughSWITCH?
- airfast
Re: POE Power cycle
Ok got it, terminology got me.
Tested and working.
Moving away from Tough Switches, too many issues,
Appreciated.
Tested and working.
Appreciated.
