I have a WS-8-150-DC that I programmatically control via SSH.
I have manually scoured the SSH commands looking for a means for the input voltage reading to be returned.
No luck - anyone have any clues?
Thanks in anticipation...
Obtain input voltage reading via SSH
Omniflux - Experienced Member
- Has thanked: 5 times
- Been thanked: 32 times
Re: Obtain input voltage reading via SSH
From WS-12-250-DC firmware 1.5.2
- Code: Select all
# show status
Power
Board 24V: 24.6 V
Board 3V: 3.3 V
Power Supply Input Voltage: 22.9 V
Power Supply Input Current: 5.3 A
Power Supply Output Voltage: 51.2 V
Many thanks, I'll give it a whirl...
I did not get the input voltages, following is transcript of putty session:
Netonix Switch# show status
System
Current Time: 08/31/2019 16:12:29
Uptime: 679.460022 seconds
CPU Usage: 16%
Memory Usage: 44.73 MB
MAC Address: ec:13:b2:e1:45:a0
IP Address: 192.168.0.20
IPv6 Address: fe80::ee13:b2ff:fee1:45a0
Firmware Version: 1.5.0rc4
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 27 C
CPU Temp: 43 C
PHY Temp: 38 C
Cooling
Fan 1 Speed: 0 RPM
Netonix Switch#
Any further suggestions????
Thanks in advance...
System
CPU Usage: 16%
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 27 C
CPU Temp: 43 C
PHY Temp: 38 C
Cooling
Fan 1 Speed: 0 RPM
Netonix Switch#
Maybe via snmp (could use snmpwalk on remote device)?
dcdcInputCurrent OBJECT-TYPE
SYNTAX CurrentTC
MAX-ACCESS read-only
STATUS current
DESCRIPTION "DCDC Input Current in amps"
::= { netonixSwitch 7 }
Source: http://forum.netonix.com/firmware/NETON ... CH-MIB.dat
SYNTAX CurrentTC
STATUS current
I don't have a WS-8-150-DC I can compare with at the moment, but you are running an older firmware version than I am, so that may be the difference.
Whenever someone has an issue they should first upgrade to the latest firmware and then if issue persists open a thread.
I can see v1.5.2 but v1.5.0rcX ???? - REALLY OLD FIRMWARE
OK I upgraded to 1.5.4 and still get no input voltage readings:
System
Current Time: 09/11/2019 10:06:59
Uptime: 262.570007 seconds
CPU Usage: 10%
Memory Usage: 45.47 MB
Firmware Version: 1.5.4
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 25 C
CPU Temp: 40 C
PHY Temp: 34 C
Cooling
Fan 1 Speed: 0 RPM
System
CPU Usage: 10%
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 25 C
CPU Temp: 40 C
PHY Temp: 34 C
Cooling
Fan 1 Speed: 0 RPM
I have now upgraded to 1.5.5 - the latest and greatest - but still no input voltages.
I would really appreciate some guidance her.
log of PuTTY session:
System
Current Time: 10/16/2019 12:33:24
Uptime: 207.100006 seconds
CPU Usage: 15%
Memory Usage: 45.00 MB
Firmware Version: 1.5.5
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 31 C
CPU Temp: 46 C
PHY Temp: 40 C
Cooling
Fan 1 Speed: 0 RPM
System
CPU Usage: 15%
Model: WS-8-150-DC
Board Rev: F
Power
Board 48V: 48.9 V
Board 24V: 23.4 V
Board 3V: 3.3 V
Thermal
Board Temp: 31 C
CPU Temp: 46 C
PHY Temp: 40 C
Cooling
Fan 1 Speed: 0 RPM
- Been thanked: 208 times
I'm not seeing it on the WS-8-150-DC either. I think it's because this is technically not a smart DC switch.
I'll see about getting it added into the next RC release.
