SMTP Alert management
jfrawley
Been thanked: 4 times
Thu Jun 27, 2019 5:54 am
When will we be able to adjust which alarms we get via smtp? Also what has been done about the low voltage constant email alerts when the voltage fluctuates from lets say 24.1 to 24.0 to 24.1 It would be nice to somehow limit those types of messages maybe like if in alarm state aka low voltage send message every x min, example we are at 24.0 send alarm via smtp, check voltage again in 10 minutes if still in alarm send message etc.. we have several solar sites and its nice having that because I can then remove another piece of equipment that was used for monitoring voltage etc :) Love the switches btw we are constantly tearing out poes and dc poes and just going straight to the switch, cleans up sites very nicely!
President Leader Communications
Jason Frawley
Idaho, USA
Been thanked: 208 times
Re: SMTP Alert management
Thu Jun 27, 2019 12:46 pm
There has been a couple people posting recently about being able to pick which smtp alert's take place, so that is being added to the to-do list for possibly the next rc release as long as no major issue's come up and take priority.
The low voltage warning email spamming bug should've been fixed already, what version of firmware are you using?
