SNMP udp port on WS-12-250-DC
cherwilco
Has thanked: 3 times
Mon Jun 24, 2019 3:01 pm
I am trying to load one of our WS-12-250-DC into prtg and I have it connected via a pepwave radio with udp port 161 forwarded to the switch. I keep getting the old -2003 error in prtg and it fails to import any sensors from the switch. (No response (check: firewalls, routing, snmp settings of device, IPs, SNMP version, community, passwords etc) (SNMP error # -2003)
I have tried doing a port scan via https://www.ipfingerprints.com/portscan.php and it does show that port 161 is open and accepting connections.
any advice? I dont see anywhere in the switch config to change wich port snmp traffic uses... is that configurable?
Been thanked: 208 times
Re: SNMP udp port on WS-12-250-DC
Mon Jun 24, 2019 11:44 pm
At present the snmp port is not configurable. That's something I can look into if necessary. In the mean time have made any changes to your Access Control settings?
cherwilco
Tue Jun 25, 2019 11:05 am
No, I have left the access control tab all default settings. its set to enable with 5 attempts and 60 seconds between and nothing configured below
Tue Jun 25, 2019 12:34 pm
What version of firmware are you running at present?
cherwilco
Tue Jun 25, 2019 3:42 pm
1.5.2 Board Rev F
Tue Jun 25, 2019 9:11 pm
SNMP was definitely working in that version. Is your switch publically accessible? If it isn't, I don't see how that port scanning tool would be of much help if it can't get through your NAT. Maybe it might be better to try and run a port scan with NMAP on the host machine that has PRTG on it?
cherwilco
Fri Jun 28, 2019 5:24 pm
I did get it working, I believe the error was in my prtg configuration. all snmp data is working as expected. thank you
Mon Jul 01, 2019 12:35 pm
Glad it worked out.
