I have a DC-26 that runs fine for a random amount of time, then starts spiking latency up as high as 500-2000ms. When this happens the port details show the Rx Drop counter going up. The only thing that fixes it is a reboot. I am running the latest firmware and it is connected to a Mikrotik RB4011. We have some port based VLANS, but it is an otherwise very basic configuration.
What could be happening here?
David
RX Drops
- DesertDweller
- DesertDweller
Re: RX Drops
I think most of the drops were coming from VLAN1 not being untagged on the port, but this still doesn't explain why ping speeds spike the way they do.
- DesertDweller
Re: RX Drops
To clarify, latency to the switch is fine, but anything connected to it spikes.
- DesertDweller
- Been thanked: 208 times
Re: RX Drops
Can you post your config tab, status tab, ports tab, and vlans tab? Flow control is where we always start with something like this, but if it goes past that then we need more info. Also, if you could get the logs for about the time the latency start to occur it would also be helpful.
- AsiNetwork
Re: RX Drops
we got the same problem, is not netonix switch they are splendit fast.
We tried changing switch, cables, sfp modules.
With around 5 tower the common thing was the mikrotik RB4011, i looks that is has some kind of bug software I have seen the issue on 6.44+ software but the firsts ones that we bought had 6.43 dont have this issue.
none packet loss, ping to Directed connected devices promt 0 ms. with netonix,
We changed the routers to CCR1009 and problem gone.
Try it
Try it
Re: RX Drops
Thanks for the post AsiNetwork, I will circulate this information around to anyone else who might need it.
