Hi Guys,
Couldn't get the a ground to tighten on the lug today and ended up tearing the ground lug off the front. Is this a case ground lug or is there an internal connection that tore off? If a case lug...any old cases around?
Thx
Rob
Ground Lug Tore Off WS-12-250-DC
rkelly1 - Experienced Member
- Has thanked: 12 times
- Been thanked: 27 times
Re: Ground Lug Tore Off WS-12-250-DC
Chris - is the ground lug simply attached to the case or is there an internal connection to the lug? Need to determine if the case needs replacement, or if I can fab a lug onto the case?
Thanks.
Thanks.
Yes, you can open the chassis and look to better see but the lug is to chassis and the board gets access to it via plated screw holes on the boards.
