I would love you forever if you guys would change out your DC connectors in future models for this style, assuming you can find some rated to handle the size wire neccessary for the switch load...
Euro style DC connector
josh - Associate
- Has thanked: 69 times
- Been thanked: 31 times
Chris,
JustJoe - Experienced Member
- Has thanked: 94 times
- Been thanked: 59 times
Re: Euro style DC connector
Ah you mean like the 2 parts ones that act like a "plug" screwed on the end of your wires and the other part is the "socket" it plugs into mounted on the switch? It's possible I have seen some versions that will handle #10 stranded wire in either Digikey or Mouser.
josh - Associate
Yup. 2 wire would work, 3 wire (+/-/ground) would be better.
ryanm - Member
- Has thanked: 36 times
- Been thanked: 16 times
Phoenix connectors? Can't those things just die?
