We have a WS-12-250-DC which is providing power with 48VH (AF24) - it's working OK but the watts only reads from 0.0 to 1.0.
Any ideas why? Switch is on latest 1.5.2 and the AF24 is on 4.0.3.
WS-12-250-DC - Watts Issue
- Beanhammer
- Been thanked: 208 times
Re: WS-12-250-DC - Watts Issue
What are you seeing on the pop-up for the individual sensor readings?
(To see that, just hover the mouse over the watts or PoE column for the port on the Status tab)
My guess is your current sensors are damaged from ground current.
Do a search on this forums for ground current and current sensors and you can read about it
You will need RMA the unit for repair but fix your grounding if that is what we find when we repair your unit.
You can also BENCH TEST your unit as explained here: https://forum.netonix.com/viewtopic.php?f=6&t=2780#p19221
viewtopic.php?f=30&t=2786#p19279
viewtopic.php?f=30&t=1816
viewtopic.php?f=30&t=188
viewtopic.php?f=30&t=1429
In the event bonding service rods to tower rods is not possible then definitely add additional NEW ground rods to electrical service to help prevent service ground current from ever seeing tower ground rods as a better path to ground.
