Rolled out a brand new 12-250 AC it is weird that the fan revs up and then stops and then revs up and stops. I'm a little worried about the temperature as it is much higher than the other twin I have to compare it with, its twin is also holding fan steady at 2500 rpms
https://photos.app.goo.gl/RK48JMUnzbn8uc6k9
its just the coming netflix rush at a mountaintop site, nothing to worry about right ?
Odd fan behavior, temp climbing
Re: Odd fan behavior, temp climbing
2500 RPM is a thing of the past, not to be seen again on newer firmware.
rockhead - Experienced Member
- Has thanked: 53 times
- Been thanked: 35 times
Good to know, sure seems odd though and the temp looks high, cpu seems to have levelled at 84C
You NEED to install v1.5.2rc5 for proper fan control.
Please upgrade to v1.5.2rc5
SUNON changed their fans and the new software is needed to properly drive them.
viewtopic.php?f=17&t=3914&p=27564&hilit=+sunon+firmware+fan#p27564
viewtopic.php?f=6&t=4918&p=27922&hilit=+sunon+firmware+fan#p27922
viewtopic.php?f=6&t=1681&p=27464&hilit=+sunon+firmware+fan#p27464
Wooohoo, chillin like a villain, thanks man
69C and still declining
