Request: Select / Deselect Ports in Graphic
uberdome
Has thanked: 3 times
Been thanked: 11 times
Wed Feb 06, 2019 1:15 pm
Ports can be selected and deselected in their description in the tables, but not from the graphic representation at the top. In the graphic, ports can only be selected, not deselected.
Please add deselection capability to the top graphic.
This was tested most recently in 1.5.2rc1.
Re: Request: Select / Deselect Ports in Graphic
Wed Feb 06, 2019 1:41 pm
Click on the right or left margin to deselect.
uberdome
Wed Feb 06, 2019 1:51 pm
Thank you, that is very helpful.
I still think it would be nice if it was in the graphic itself as well, since that is intuitive, but the margin clicking is helpful.
Wed Feb 06, 2019 2:11 pm
uberdome wrote:Thank you, that is very helpful.
So, say click Port 1 to select then select Port 1 again to deselect.
I will say something to Stephen for next release as that should be simple change.
uberdome
Wed Feb 06, 2019 2:37 pm
sirhc wrote:So, say click Port 1 to select then select Port 1 again to deselect.
Exactly, thank you very much.
Been thanked: 208 times
Fri Feb 08, 2019 2:42 pm
This feature has been added, it will be in a release made by the end of today.
uberdome
Fri Feb 08, 2019 9:37 pm
Very nice, this is working in v1.5.2rc3. Thank you!
