Factory Default WS-26-500-DC?
intellipop
Has thanked: 7 times
Tue Feb 05, 2019 4:31 pm
Dumb question: where is the factory default button on these? I swear I've looked all over
I see a hole labeled "DEF" but it doesn't seem to do anything when I push into it with a pin, and I have no idea what the IP is on this thing.
Thank you for the help
Re: Factory Default WS-26-500-DC?
Tue Feb 05, 2019 4:38 pm
The factory default is pretty much the same on all our switches.
Yes that small hole is the button.
Read this post: viewtopic.php?f=6&t=409#p2398
Hook up a console cable as well.
intellipop
Tue Feb 05, 2019 4:45 pm
Turns out something got stuck in the DEF hole and it wasn't depressing -_-
Thank you
