-30 temp here currently and I have two switches that are flapping the LAN ports now that its cold out. Nothing is getting power cycled, the ports just go from 1gbps to 100mbps to down.
WS-12-250AC
firmware 1.4.5
~120watt draw
26C board temp
WS-24-400A
firmware 1.4.7rc14
~150watt draw
Both switches are powering Prism AP's and an AF5X.
I realize this is old firmware. A GUI reboot has actually resolved the issue for the past 5 minutes for me at the DC site. The AC site is still port flapping. Any ideas?
Switches port flapping in cold
Re: Switches port flapping in cold
I have powered off 4 of the 12 sectors on the 24port and things appears to have stabilized for now.
- wmtel
We are having the same issue here (temp is -22F right now). I am going to try powering down ports and see if that helps. Thanks!
My guess is this is more of temperature contraction of parts like EThernet connectors.
Several times a year we have to dispatch tower guys to simply unplug and replug Ethernet connector. Normally happens in extreme temp ranges cold or hot.
viewtopic.php?f=14&t=4933#p28000
Interesting.... But shutting off POE to a few of the ports to reduce power draw resolves the issue for us. Just very odd....
Wifimax wrote:Interesting.... But shutting off POE to a few of the ports to reduce power draw resolves the issue for us. Just very odd....
Then read this post: viewtopic.php?f=17&t=3934#p24989
And this thread: viewtopic.php?f=17&t=4930#p27991
