Port Learing/Forwarding/Disarding Repeatedly
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Thu Jan 24, 2019 8:15 pm
What is this? is this spanning tree engaging? I assume it's not a port flap since the port isn't actually showing as up/down?
Code: Select all
Jan 22 18:33:55 STP: set port 3 to discarding
Jan 22 18:33:55 STP: set port 3 to learning
Jan 22 18:33:55 STP: set port 3 to forwarding
Jan 22 21:20:00 STP: set port 3 to discarding
Jan 22 21:20:00 STP: set port 3 to learning
Jan 22 21:20:00 STP: set port 3 to forwarding
Jan 22 21:45:05 STP: set port 3 to discarding
Jan 22 21:45:05 STP: set port 3 to learning
Jan 22 21:45:05 STP: set port 3 to forwarding
Jan 23 03:13:25 STP: set port 3 to discarding
Jan 23 03:13:25 STP: set port 3 to learning
Jan 23 03:13:25 STP: set port 3 to forwarding
Jan 23 03:19:37 STP: set port 3 to discarding
Jan 23 03:19:37 STP: set port 3 to learning
Jan 23 03:19:37 STP: set port 3 to forwarding
Jan 23 06:59:56 STP: set port 3 to discarding
Jan 23 06:59:56 STP: set port 3 to learning
Jan 23 06:59:56 STP: set port 3 to forwarding
Jan 23 08:52:26 STP: set port 3 to discarding
Jan 23 08:52:26 STP: set port 3 to learning
Jan 23 08:52:26 STP: set port 3 to forwarding
Jan 23 10:06:47 STP: set port 3 to discarding
Jan 23 10:06:47 STP: set port 3 to learning
Jan 23 10:06:47 STP: set port 3 to forwarding
Jan 23 10:24:09 STP: set port 3 to discarding
Jan 23 10:24:09 STP: set port 3 to learning
Jan 23 10:24:09 STP: set port 3 to forwarding
Jan 23 18:52:44 STP: set port 3 to discarding
Jan 23 18:52:44 STP: set port 3 to learning
Jan 23 18:52:44 STP: set port 3 to forwarding
Jan 24 07:41:19 STP: set port 3 to discarding
Jan 24 07:41:19 STP: set port 3 to learning
Jan 24 07:41:19 STP: set port 3 to forwarding
Jan 24 17:26:39 STP: set port 3 to discarding
Jan 24 17:26:39 STP: set port 3 to learning
Jan 24 17:26:39 STP: set port 3 to forwarding
Jan 24 17:57:12 STP: set port 3 to discarding
Jan 24 17:57:12 STP: set port 3 to learning
Jan 24 17:57:12 STP: set port 3 to forwarding
Re: Port Learing/Forwarding/Disarding Repeatedly
Thu Jan 24, 2019 9:06 pm
Seem like a loop detected by STP.
