Jan 1 01:00:04 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 01:00:04 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 01:00:04 kernel: TCP reno registered
Jan 1 01:00:04 kernel: NET: Registered protocol family 1
Jan 1 01:00:04 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan 1 01:00:04 kernel: Registering mini_fo version $Id$
Jan 1 01:00:04 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Jan 1 01:00:04 kernel: msgmni has been set to 246
Jan 1 01:00:04 kernel: io scheduler noop registered
Jan 1 01:00:04 kernel: io scheduler deadline registered (default)
Jan 1 01:00:04 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
Jan 1 01:00:04 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 16550A
Jan 1 01:00:04 kernel: console [ttyS0] enabled
Jan 1 01:00:04 kernel: No NAND device found!!!
Jan 1 01:00:04 kernel: m25p80 spi0.0: m25p128 (16384 Kbytes)
Jan 1 01:00:04 kernel: Mapped SPI read area @0x40000000 len 16777216
Jan 1 01:00:04 kernel: Creating 10 MTD partitions on "m25p80":
Jan 1 01:00:04 kernel: 0x00000000-0x00040000 : "RedBoot"
Jan 1 01:00:04 kernel: 0x00040000-0x00080000 : "config"
Jan 1 01:00:04 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Jan 1 01:00:04 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Jan 1 01:00:04 kernel: 0x003c0000-0x00500000 : "linux"
Jan 1 01:00:04 kernel: 0x00500000-0x00b00000 : "rootfs"
Jan 1 01:00:04 kernel: mtd: partition "rootfs" set to be root filesystem
Jan 1 01:00:04 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Jan 1 01:00:04 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Jan 1 01:00:04 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Jan 1 01:00:04 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"
Jan 1 01:00:04 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:04 kernel: TCP cubic registered
Jan 1 01:00:04 kernel: NET: Registered protocol family 10
Jan 1 01:00:04 kernel: lo: Disabled Privacy Extensions
Jan 1 01:00:04 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 01:00:04 kernel: NET: Registered protocol family 17
Jan 1 01:00:04 kernel: 802.1Q VLAN Support v1.8 Ben Greear
Jan 1 01:00:04 kernel: All bugs added by David S. Miller
Jan 1 01:00:04 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 01:00:04 kernel: Freeing unused kernel memory: 116k freed
Jan 1 01:00:04 kernel: Please be patient, while OpenWrt loads ...
Jan 1 01:00:04 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 01:00:04 kernel: mini_fo: using base directory: /
Jan 1 01:00:04 kernel: mini_fo: using storage directory: /jffs
Jan 1 01:00:04 sysinit: killall: udhcpc: no process killed
Jan 1 01:00:07 kernel: vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
Jan 1 01:00:07 kernel: switch: 'Luton26' board detected
Jan 1 01:00:09 kernel: vtss_port: Loaded port module on board Luton26, type 5
Jan 1 01:00:09 kernel: nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Jan 1 01:00:10 kernel: i2c /dev entries driver
Jan 1 01:00:10 kernel: i2c_vcoreiii i2c_vcoreiii: i2c bus driver on IRQ 19
Jan 1 01:00:11 sysinit: Loading defaults
Jan 1 01:00:11 sysinit: Adding custom chains
Jan 1 01:00:12 sysinit: Loading zones
Jan 1 01:00:12 sysinit: Loading forwarding
Jan 1 01:00:12 sysinit: Loading redirects
Jan 1 01:00:12 sysinit: Loading rules
Jan 1 01:00:12 sysinit: Loading includes
Jan 1 01:00:21 kernel: eth0: no IPv6 routers present
Jan 1 01:00:21 kernel: eth0.100: no IPv6 routers present
Jan 1 01:00:26 sysinit: killall: telnetd: no process killed
Jan 1 01:00:28 sysinit: 1970-01-01 01:00:27: (log.c.216) server started
is it a Problem with no nand device?
- dgerlach@disquom.de
Re: No NAND device found!!!
No this is not an issue, its normal.
We are using a standard bootloader that addresses more types of hardware then we are using.
Users browsing this forum: No registered users and 94 guests
