MWhat exactly is loop protection in the GUI?
Is it what I assume, protection from an Ethernet loop?
If so, is it possible to get false alarms?
I have a WS-MINI that has one port inbound (6) and 5 customer facing ports - some to PtP links, one to PtMP link, one to PC link
I get these random loop protection warnings in the log...
Jan 2 16:45:03 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 2 16:48:04 Loop protection: re-enabling port 6
Jan 3 17:02:33 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:05:35 Loop protection: re-enabling port 6
Jan 3 17:08:58 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:12:00 Loop protection: re-enabling port 6
Jan 3 17:18:15 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:21:17 Loop protection: re-enabling port 6
Jan 3 17:21:25 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:24:27 Loop protection: re-enabling port 6
Jan 3 17:25:04 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:28:05 Loop protection: re-enabling port 6
Jan 3 17:28:27 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:31:28 Loop protection: re-enabling port 6
Jan 3 17:31:35 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 17:34:36 Loop protection: re-enabling port 6
Jan 3 21:12:53 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 3 21:15:54 Loop protection: re-enabling port 6
Jan 4 06:39:46 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 06:42:47 Loop protection: re-enabling port 6
Jan 4 07:38:31 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 07:41:32 Loop protection: re-enabling port 6
Jan 4 07:42:50 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 07:45:51 Loop protection: re-enabling port 6
Jan 4 08:07:52 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 08:10:53 Loop protection: re-enabling port 6
Jan 4 08:20:21 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 08:23:22 Loop protection: re-enabling port 6
Jan 4 08:23:37 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 08:26:38 Loop protection: re-enabling port 6
Jan 4 09:41:01 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 09:44:03 Loop protection: re-enabling port 6
Jan 4 10:02:56 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:05:58 Loop protection: re-enabling port 6
Jan 4 10:06:05 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:09:07 Loop protection: re-enabling port 6
Jan 4 10:09:13 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:12:15 Loop protection: re-enabling port 6
Jan 4 10:12:26 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:15:28 Loop protection: re-enabling port 6
Jan 4 10:25:25 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:28:27 Loop protection: re-enabling port 6
Jan 4 10:49:15 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 10:52:17 Loop protection: re-enabling port 6
Jan 4 11:21:59 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 11:25:01 Loop protection: re-enabling port 6
Jan 4 11:50:24 Loop protection: detected loop from port 6 to port 6, disabling port 6 for 180 seconds
Jan 4 11:53:26 Loop protection: re-enabling port 6
Jan 4 11:58:55 UI: Configuration changed by admin (x.x.x.x)
Jan 4 11:58:55 UI: Storm_Control_Loop_Protection: changed from 'Enabled' to 'Disabled'
Any suggestions?
loop protection
dcox - Member
- Has thanked: 5 times
loop protection
Re: loop protection
Yes, loop protection is a ethernet loop protection to protect the switch where STP can't.
Hard to say why without a pcap file, what can be done via a port mirroring to a PC with tcpdump or wireshark.
Layer 2 or 3 device connected to port 6 ? If layer 2, last firmware on layer 2 devices connected to ports 6 ?
If you go to the tab "Device", sub-menu "Configuration", section "Storm Control", you can higher the value for "Loop Protection" to disable the port (Broadcast, Muticast, Unicat), so Loop Protection would be less sensitive.
Users browsing this forum: No registered users and 93 guests
