Hi
The transformer on port 3 of this switch is blown (confirmed by removing it). Everything else is intact and I have the tools to do the reflow work but I've been unable to locate a supplier for the transformer module. The switch also needs a new fan which I can purchase from your replacement parts store. Is it possible to purchase a couple of the transformer modules as well?
Ian
Replacement magnetics for WS-12-250-AC
- ifreislich
Re: Replacement magnetics for WS-12-250-AC
VSC7425XJG-02 cpu/phy are you sure you are working?
- ifreislich
The part I need is the G50214SNGX. The PHY is OK.
ifreislich wrote:The part I need is the G50214SNGX. The PHY is OK.
Transformer I need too.But not found
I forgot
@sirhc told me I would help. but I couldn't communicate.
Users browsing this forum: No registered users and 93 guests
