Fallback IP-address ?
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Sat Feb 14, 2015 9:20 am
Is it possible to somehow add a fallback IP-address, when management interface is set to DHCP and there is no DHCP server on the network ?
Re: Fallback IP-address ?
Sat Feb 14, 2015 10:31 am
jjonsson wrote:Is it possible to somehow add a fallback IP-address, when management interface is set to DHCP and there is no DHCP server on the network ?
Currently it does not do this but we have discussed it.
Sat Feb 14, 2015 1:19 pm
Chris, have you tested to see if using static ARP would work? A lot of embedded devices I've worked on use static ARP for the initial configuration to get in to setup the IP.
Also, MAC-Telnet/MAC-SSH... anything to save having to fiddle with a serial console cable as a last resort.
http://aouyar.github.io/MAC-Telnet/
jjonsson
Sat Mar 07, 2015 7:58 am
I lost contact to a switch. It hasn't for some reason got an IP-address from the DHCP server. Quite annoying that I have to connect console cable. Fallback IP-address would be better choice as I know that one of the ports is configured to untagged on the management LAN.
@Sirhc please!
amishgenius
Has thanked: 44 times
Been thanked: 45 times
Sat Mar 07, 2015 10:20 am
+1 on fallback IP
Sat Mar 07, 2015 10:39 am
I will put fallback IP on the firmware road map.
jjonsson
Sat Mar 07, 2015 5:06 pm
Chris,
Please do and make it toppriority :-)
Sat Mar 07, 2015 9:29 pm
I finalized v1.2.0 features.
Eric will work on them this coming week
adairw
Has thanked: 98 times
Been thanked: 132 times
Sat Mar 07, 2015 10:47 pm
Just my .02. but why would you ever depend on DHCP for a management device? Seems to risky.
Mac-telnet/ssh with a little app to discover it would seem way more useful to me than fallback-ip.
ralliart12
Has thanked: 12 times
Fri Aug 21, 2015 9:32 am
jjonsson wrote:I lost contact to a switch. It hasn't for some reason got an IP-address from the DHCP server. ..
May I know what was the last few changes you do that caused the switch to not obtain an IP from your DHCP server?
The same issue happened to mine & I will like to trace if we did the same thing to cause this to happen.
In my case, everything still work, i.e. I can still hit the external network via devices that are hooked up through the switch, it's just that I can't hit the switch's admin page via its last-known DHCP-assigned IP address.
Users browsing this forum: No registered users and 113 guests
