Netonix Manager Upgrade
stevebarnes35
Mon Nov 05, 2018 2:20 pm
Have a windows 2008 Virtual Server that Netonix manager has run perfectly on for a year. Noticed the upgrade is available from 1.0.7 to 1.0.10 So I clicked on update. It started and never finished. I reloaded and it said there was an error do you want to send the Log to Netonix. I told it yes. What do I do now. I have rebooted the server. 1.0.7 Works perfectly.
Eric Stern
Been thanked: 130 times
Re: Netonix Manager Upgrade
Mon Nov 05, 2018 5:29 pm
You need to upgrade nodejs to 8.11.3 or newer.
