Watts column display errors on status screen
GregColon
Sun Oct 21, 2018 6:12 pm
I recently purchased the WS-12-250-AC, the minute I plug multiple PoE devices on it the screen changes with Error under the Watts column. The status screen shows errors as well plus the fan is always running regardless that this switch is in a temperature control room. I have reset the switch multiple times and uploaded the firmware with the v1.5.0 release. Should this be sent for RMA? Please advise…
Thank you!
Greg
Status Screen
Status System Screen
Re: Watts column display errors on status screen
Sun Oct 21, 2018 8:41 pm
jagman2020
Been thanked: 3 times
Mon Jan 28, 2019 10:41 pm
OK.. Will RMA when I get the chance to swap it out..
It is earthed correctly to all areas.. but i will check that when we put the replacement in.
