I am getting this error on all ports on a WS-12-250-DC "Error loading cable diagnostics". I have a Ubiquiti PBE-M2-400 and it's pulling 25-30 watts rather than the normal 3-5 watts and I don't know if it's the radio or the cable. The radio is passing traffic normally. I've re-booted the radio several times and re-booted the switch. The other radios all seem to be drawing the 3-5 watts.
Has anyone seen this before or have any ideas of what could be the cause?
John
cable diagnostics
- JohnWall
Re: cable diagnostics
- JohnWall
Will do. It's also giving me the message 'Error saving configuration!'. Then it takes a long time to apply, but it does when I refresh the screen.
I'll let you know the results early next week.
John
John
- JohnWall
Thanks sirhc
Finally got the switch on the bench and upgraded the firmware. It seems to be working just fine now.
JohnWall wrote:Thanks sirhc
I would factory default it in case there is any corruption in the config file.
