SFP Mikrotik PROBLEM
- alfonsourbina
Are you working on any solution to this problem? It is specifically with Mikrotik's SFP, the link is lost and it returns (it is connected on port 14, WS-12-250-DC) . All that happens with version 1.5.0 onwards. In 1.4.9 the problems in this respect are minor, although they also eventually occur
Re: SFP Mikrotik PROBLEM
I found a solution for Mikrotik SFP (mostly tryed RJ45 stick adaptor), I putted those to trash after encountering several problems with several brands. For RJ45 stick adaptor, Robofiber work really fine with most devices. For standard SFP, FS are cheap and Cisco compatible one also generally work fine with most devices.
- Has thanked: 362 times
- Been thanked: 87 times
I have same experience as mike99, not worth trying to use MT SFP
