MIKROTIK SFP PROBLEM
- alfonsourbina
I have a switch configuration connected to a CCR1009 through the S + DA0001 fiber cable from Mikrotik. I have vlans truncated by said SFP, when I do it, with version 1.5.x every 30 seconds traffic stops flowing and all the vlans fall, after a few seconds they are restored. This does not happen if I have version 1.4.9 installed. Is there any information about it?
Re: MIKROTIK SFP PROBLEM
Did you try setting the SFP Speed/Duplex to 1G on both sides and or Auto on both sides?
Some SFP modules like 1G some like AUTO but needs to be the same on both sides of link.
Could you post up the follow TABs
Ports / LAG / STP / Device/Status
Please read my post footer for instruction to load images to your post.
I would suspect STP issue, broadcast strom protection issue, or an other similar option. Any log ?
