Watts column disappears on WS-24-400A with 1.4.9
tma
Has thanked: 15 times
Been thanked: 14 times
Fri Aug 10, 2018 7:36 pm
We deployed a WS-24-400A (rev E with fw 1.4.9) today and it's working fine. However, when I log in, I can only briefly see the "Watts" column header, but when the UI has finished loading data for the Status dashboard, the "Watts" column gets hidden. Also, the watts bar at the top only shows the total Watts usage but not for individual PoE ports when I select them. The only way I can see power usage per port is by selecting a port and switch the right graph at the bottom to show power usage.
That is, the UI seems to get power usage data, but for some reason decides that it is a switch without PoE or so. My question is whether this is something to worry about in terms of operational stability to be expected, i.e. something is wrong with this device. Or maybe you suspect it's only a glitch in the firmware and you want me to restart before we decide to swap it (this is a production unit on a site with sensitive customers).
Advice appreciated.
Thomas Giger
Re: Watts column disappears on WS-24-400A with 1.4.9
Fri Aug 10, 2018 7:41 pm
Use another browser
Also upgrade to v1.5.0
