We have a WS-6-MINI that can be factory reset and used briefly but after a short time becomes unresponsive and doesn't pass traffic. It displayed this on the bench during initial config and never was deployed.
I was able to update the firmware but it didn't help.
Anything else I should try before RMA?
WS-6-MINI Unresponsive
Re: WS-6-MINI Unresponsive
Are you saying that you can factory default it.
Simply let it set running on the bench in a factory defaulted state and changing nothing in the config it becomes unresponsive just setting there making no changes to the config?
brock - Member
- Has thanked: 3 times
I think that is correct, I will double-check. We are not doing anything exotic with it, I took another one out of the box and configured, tested, deployed no problem, and have done another one since.
brock wrote:I think that is correct, I will double-check. We are not doing anything exotic with it, I took another one out of the box and configured, tested, deployed no problem, and have done another one since.
Then I would say you need to RMA that unit.
