Console with no password
glendale2x
Fri Jul 06, 2018 8:21 pm
Today I accidentally found out you can bypass login/password on the serial console. This is on firmware 1.4.9
Connected using serial console I did this:
Code: Select all
Please press Enter to activate this console.
BusyBox v1.19.4 (2017-03-07 13:42:37 EST) built-in shell (ash)
Username:
Username:
Username:
Username:
Username:
Username:
Username:
Username:
Username: lkjasdfa
Password: ******
^Cswitchtest#
switchtest#
Basically, enter any random invalid user/password and hit ctrl-c after you hit enter to drop into command line.
Re: Console with no password
Fri Jul 06, 2018 8:40 pm
Please upgrade to v1.5.0 or v1.5.1rc1 and confirm issue still there.
If so I will assign a programmer to fix it.
