Upgraded no problem, but lost communication to and through two of my AP's plugged into ports 8 and 9 on two separate VLANs. Reverted back to rc5 and still nothing. Disabled vlan, re-enabled, deleted and added, still nothing. Bounced the ports and the units reboot as normal, just no pings or communication through the ports as if the VLAN config is trashed.
A little help?
Upgrade to 1.0.10rc6 Failure
- Been thanked: 1362 times
Re: Upgrade to 1.0.10rc6 Failure
Not sure, I upgraded my WISP switches with no issues?
There was literally no other changes done to the firmware from v1.0.10rc5 other than how it reacts on a reboot after power failure - COLD BOOT?
WisTech - Associate
- Has thanked: 9 times
- Been thanked: 64 times
I'm looking at the MAC table and showing multiple VLAN's across different VLAN ports, I have 2 problematic radios (ports), the others are fine.
If your switch is easily accessed I would upgraded it back to v1.0.10rc6 then power cycle it (COLD BOOT).
We should probably put an option in the UI to preform a "COLD REBOOT" which will unfortunately bounce the POE ports but may from time to time be needed/useful as embedded devices are really no different than computers in that sometimes they just need a COLD REBOOT or power cycle to fix something squirrely?.
I am really sorry for your troubles on New Years Eve, my bad!
WisTech - Associate
Chris - An actual reboot (after firmware upgrade) resolved it temporarily, then ports 8,9 and 11 are all crossed up. The other ports operate fine and are isolated. Guess I'll take the spare 24 and take a drive.
Will let you know. Thanks man. What sucks more is whiny customers.
WisTech - Associate
Chris - I disabled the VLANs on both of the problematic ports, rebooted (remotely), then enabled one and applied, everything came back up normally... waited, then enabled the other port. Everything still seems to be functioning normally. I'll keep an eye on it and report back.
Thanks for your help.
PS - I'm still on RC5, dad's shitting a brick because I did it during business hours.
Tony
Tony
I am really sorry Tony but yes keep me posted, I am staying home tonight and working.
My guess is your unit got confused and really could use a cold reboot, it happens sadly.
Users browsing this forum: No registered users and 240 guests
