Hey guys,
Recently i was trying to reach my interface but it didn't connect..
i tried to cold reset via console, but even after that it's still unreachable... i'd appreciate any help
Greetings
ws-8-150-dc interface is not working anymore
schneeweiss - Member
Re: ws-8-150-dc interface is not working anymore
What version firmware was you using?
Can you SSH to the unit?
Can you ping the unit?
Hook up a console cable and see what's going on.
sirhc wrote:What version firmware was you using?
Hello, sorry for the late answer.
I actually did reset the router via console cable ... its not pingable nor sshable ..
It now uses 1.4.5rc2 i don't really know which firmware was on before reset..
Take out of service and do these things:
Do a power on factory default, see instructions here: viewtopic.php?f=6&t=409#p2398
Upgrade to v1.5.0
Do a Bench test as described here: viewtopic.php?f=6&t=2780#p19221
Upgrade to v1.5.0
Upgrading the Firmware via CLI fixed the issue, thank you
