v1.5.0 Bug reports and Comments
Mon Jun 04, 2018 8:50 pm
Please post bug reports and comments on v1.5.0 ONLY in this thread.
v1.5.0 wrote:FIXED/CHANGED
- Fixed I2C service to deal with errors better to prevent reboots with WS-12-250-DC and WS-26-500-DC
- Fixed sending CDP frames tagged with VID 1 if the management VLAN is not VID 1
- Fixed SNMP walk failing if VLANs are not in numerical order
- Fixed using hash mark in SMTP password
- Fixed using hash mark in RADIUS password
- Fixed issues with Loop Protection on SFP ports
- Fixed intermittent telemetry error on Device/Status TAB mostly seen with WS-26-500-DC
- Fixed power TAB shutdown time set to 12 AM would turn off poe on that port]
- Fixed ST/RSTP bridge priority change would not update properly
- Fixed cli on WS-8-150-DC model's allowing one to set the power restart/shutoff from cli
- Fixed scheduled portbounce to no longer trigger unexpected link status change email
- Fixed SNMP broken in v1.5.0rc5 due to a build mistake
- Fixed SNMP handling longer firmware version
- Extended length for URL resource for SMTP recipient address
ENHANCEMENTS
- Optimized code to reduce CPU utilization especially needed for the WS-26-500-DC
- Changed watchdog waits + Interval seconds before checking again after watchdog is triggered
- Added log entry to report if the switch rebooted due to watchdog timer
- Added lldpRemPortId, lldpRemPortIdSubtype, and lldpRemPortDesc to LLDP-MIB
- Added cdpCacheDevicePort to CISCO-CDP-MIB
- Added popover for POE enabled ports on 'Watts' column to show power usage on each pair for VH ports
- Added root bridge id to STP log message
- Added Low Voltage notification for DC model's to contain the threshold and the present value in the log/email
- SNMP Contact and Location character limit increased from 26 to 255 characters
- Improved ability to deal with loops while loop protection, flow control, and STP disabled to not reboot
- Added checkbox to SYSLOG Configuration called "Log Name" which appends the switch name to messages
- Added Calling-Station-Id to RADIUS attributes to allow freeradius to log ip address of client
KNOWN ISSUES
- IGMP snooping over VLANS, MSTP, and ERPS are still being developed
Released 6/4/2018
aaron@futuretk.com
Re: v1.5.0 Bug reports and Comments
Wed Jun 06, 2018 1:21 pm
Chris,
Updating to 1.5.0 seems to power cycle all connected PoE devices at the end of the update. I don't believe I've seen that behavior before. I just applied it to a WS-26-500-DC in our lab environment, and it appears to have powercycle a connected CCR1009 once at the end of the update, and a second during the reboot it performs just after the update.
Is this expected behavior?
Wed Jun 06, 2018 5:34 pm
Sometimes a firmware upgrade will cause a cold boot, this is not intended but can happen in frequently.
This is not new to v1.5.0 as we have seen this in previous versions and have no idea why.
I upgraded 12 switches the other day and 1 did a cold reboot power cycling the POE the other 11 rebooted properly leaving the POE ON.
Not sure why it happens every so often but sometimes it does.
coreinput
Been thanked: 14 times
Wed Jun 06, 2018 5:53 pm
Upgraded from 1.4.8 after 202 days uptime and everything went smooth (and no POE loss).
Hats off to Eric and team including the beta testers for making this a good release.
Thanks!
slimey
Thu Jun 07, 2018 1:44 am
Upgrading from 1.5.0rc3 to 1.5.0 I noticed this error during the upgrade process...
Do not turn off power while upgrade is in progress!
Uploading firmware file ...
Unpacking firmware ...
/usr/bin/firmware_upgrade: line 164: //: Permission denied
Running preflash script ...
Unlocking /dev/mtd8 ...
Writing from redboot_recovery_config to /dev/mtd8 ...
Unlocking linux ...
Writing from kernel.img to linux ...
Upgrade seems to work fine, though...
Eric Stern
Been thanked: 130 times
Thu Jun 07, 2018 9:43 am
slimey wrote:Upgrading from 1.5.0rc3 to 1.5.0 I noticed this error during the upgrade process...
Unlocking linux ...
Just a small typo in the upgrade script, won't affect anything.
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Thu Jun 07, 2018 9:50 pm
Small typo? Gulp. What’s that line suppose to do?
sporkman
Has thanked: 8 times
Been thanked: 11 times
Fri Jun 08, 2018 3:09 am
Perhaps it's a shell script, and someone used a PHP comment (//) instead of a (#). The system tries to "execute" //, which isn't happening (and would be harmless).
Fri Jun 08, 2018 8:46 am
Reported
Eric Stern wrote:Just a small typo in the upgrade script, won't affect anything.
Answered
mhoppes wrote:Small typo? Gulp. What’s that line suppose to do? :willy:
If it was harmful in anyway we would tell you, Eric told you above that it was a small typo and was harmless.
sporkman wrote:Perhaps it's a shell script, and someone used a PHP comment (//) instead of a (#). The system tries to "execute" //, which isn't happening (and would be harmless).
Sporkman nailed it. :hurray:
This was copied from our internal Skype conversation:
Eric Stern wrote:
I mistakenly used // for a comment instead of #
Will not hurt anything other than report an erroneous error message
Fixed it and replaced v1.5.0 in the download section
LRL
Has thanked: 19 times
Been thanked: 49 times
Mon Jun 11, 2018 5:33 am
Tonight I upgraded several switches to 1.5.0 and all except one went off without issues.
The problem child is a ws-12-250-dc was running 1.4.9. Upon upgrade the switch went as normal but never came back up after. Upon arriving on site I found the switch to have no lights except a few green lights internally on what appear to be on the power supply board. Removing DC from the terminals for a few seconds and reconnecting brought the switch back to life.
The status page shows:
Firmware Version 1.5.0
Board Rev F
Power Supply Firmware Version 70
Power Supply Board Rev B
I'm curious to know if there was a PS Firmware change here too and if it should be running 70?
-LRL
