I have a wisp 250B, Firmware 1.0.9 - I've just set the port names to things like:
NB-32 Northfields AC [3.0]
and
NB-30 Brake AC [2.3] (unused)
I then hit save/apply, and the switch is now unresponsive.
We cannot go near the tower till daylight tomorrow (Its still on test, its only disabled Aircontrol).
Is it a case of avoiding characters like '[' or '(' in the port names? Has anyone else seen this (or do you have more sane naming standards than I?)
Cheers,
---* Bill
Setting Port names with '[' or '(' characters..
billbuchan - Member
- Has thanked: 42 times
- Been thanked: 34 times
- Been thanked: 1362 times
Re: Setting Port names with '[' or '(' characters..
To be honest I never tried using brackets and such. I asked the programmer to answer this request in a bit as I am headed out on a date with the wife before I have a date with a divorce attorney as apparently "I have been working too much these past 6 months"-- geesh, woman!
billbuchan - Member
Been there, done that. Go on the date. This issue isn't affecting us - go take her to see 'Notting Hill', get some decent Champagne, Strawberries and get grovelling.. ;)
Always works for me.
Cheers,
---* Bill
Cheers,
---* Bill
Eric Stern - Employee
- Been thanked: 130 times
You cannot break the switch by entering brackets or any other characters in those fields. There must be a different cause for your problem
josh - Associate
- Has thanked: 69 times
- Been thanked: 31 times
Going to try and replicate...
josh - Associate
Tried on firmware 1.0.9rc3
Cannot replicate.
Was expecting improper field validation/poor handling of escape sequences, but seems to work properly.
Cannot replicate.
billbuchan - Member
Thanks for quickly validating this. The sun is now coming up over rural Scotland - I should be able to get to the tower in the next couple of hours.
---* Bill
http://www.Marykirk.com
---* Bill
mhoppes - Associate
- Has thanked: 10 times
- Been thanked: 125 times
Hi Bill,
Any updates on this?
billbuchan - Member
Sorry - I was forbidden to access the internet over the holidays. Just back on now.
Yes, I've got my switch back, loving it to bits. I've not implemented the port names using '[' or '(' characters, and I've not had a 'dead stop' failure. Sorry I didn't narrow it down a bit more.
Cheers
---* Bill
Cheers
---* Bill
Users browsing this forum: No registered users and 215 guests
