Trying to log into a WS-12-250-DC the login page loads, but after presenting credentials, the following page will start to load, but never finish. I only get a blank white page, and the page refreshes itself every 10 seconds or so for as long as I leave it open. I've tried restarting the http server via SSH as well as power cycling the device, but there is no change. The issue occurs on both HTTP and HTTPS as well as on multiple browsers and computers. Attempting to login with incorrect credentials, the page will provide the expected incorrect username/password error.
Is there anything I can try to get the web interface to load properly?
Web UI login stuck in loop
- collind
Re: Web UI login stuck in loop
hi! I have the same problem. If you have any response, please contact me. Thanks!
Try a differnt browser and or computer
If that shows no love then:
Login to the console
type "sh status" press [Enter]
Take a screen grab and post here.
Hello
Having the same problem
Here is the status
XXX Netonix # sh status
System
Current Time: 06/09/2018 09:35:46
Uptime: 60728.281250 seconds
CPU Usage: 100%
Memory Usage: 42.38 MB
MAC Address: ec:13:b2:dX:XX:XX
IP Address: XX.XX.XX.XX
IPv6 Address: fe80::ee13:b2ff:fed1:6740
Firmware Version: 1.4.8
Model: WS-8-150-AC
Board Rev: F
Power
Board 48V: 50.5 V
Board 24V: 23.9 V
Board 3V: 3.3 V
Thermal
Board Temp: 40 C
CPU Temp: 61 C
PHY Temp: 61 C
Cooling
Fan 1 Speed: 2700 RPM
XXXX Netonix #
Here is the status
System
CPU Usage: 100%
Model: WS-8-150-AC
Board Rev: F
Power
Board 48V: 50.5 V
Board 24V: 23.9 V
Board 3V: 3.3 V
Thermal
Board Temp: 40 C
CPU Temp: 61 C
PHY Temp: 61 C
Cooling
XXXX Netonix #
Reboot the switch
If that fails factory default the switch using the power on factory default by holding in the default button while powering up
Your running a 1 year+ old firmware that has security holes, hope this switch is not accessible to the web? - UPGRADE to v1.5.0
You can also check the config in the CLI to make sure the web service is running.
Reboot the switch
How can I see if there is a loop from the CLI?
Will be possible to upgrade the SW from CLI?
Thank you
Thank you
leisser wrote:How can I see if there is a loop from the CLI?
Thank you
The CLI/Console provides in line help
Simply press ? and then [Enter] for a list of commands available at that point
Yes you can do a firmware upgrade via CLI with an FTP sever/service
