TX / RX Limit - Bug or misunderstanding?
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Fri Dec 12, 2014 9:45 pm
Whenever I type a value into the TX and RX limit fields for a switch port, the box turns red and then I get an error "Invalid Fields". What's up with that?
Screen Shot 2014-12-12 at 3.43.56 PM.png (17.28 KiB) Viewed 14008 times
Screen Shot 2014-12-12 at 3.43.47 PM.png (16 KiB) Viewed 14008 times
Re: TX / RX Limit - Bug or misunderstanding?
Fri Dec 12, 2014 10:08 pm
You are NOT following the instruction provided on the UI Matt? :headb:
As you can CLEARLY see in the mouse over it shows you EXAMPLES. (see image below) :rofl4:
CLICK IMAGE TO SEE FULL SIZE
Mouse over instructions.png (113.26 KiB) Viewed 14004 times
Since the field can clearly support speed or packet limiting it needs to know what you want. (see image below)
Valid inputs would be: :idea:
512kbps
10mbps
100mbos
1000pps
5000pps
mhoppes
Fri Dec 12, 2014 10:10 pm
I did not get the mouse over... didn't we talk about this when I was down there? :)
mhoppes
Fri Dec 12, 2014 10:15 pm
Well that did it.... thanks... apparently in my haste to configure while standing in the cold I clicked in the box and didn't hover long enough :) I thought that hover thing was fixed ages ago.
mhoppes
Fri Dec 12, 2014 10:16 pm
Now... what if I want to limit PPS AND Throughput??? :)
Sat Dec 13, 2014 2:32 am
mhoppes wrote:Now... what if I want to limit PPS AND Throughput??? :)
It is a limitation of the switch core not our UI, it's one or the other.
Maybe in the future we will build a higher end switch based on a more expensive core, possibly Layer 4 that allows more ability.
But first we NEED to sell these, a LOT more of "these" to raise capital to build the MINI and DC versions of these.
mhoppes
Sat Dec 13, 2014 8:12 am
I expect to be buying two more very soon :)
rockhead
Has thanked: 53 times
Been thanked: 35 times
Sat Dec 13, 2014 7:30 pm
I see they are now available at ubnt.ca so I'll be purchasing through the distributor to keep them buying too !
