Restore Config from text file
qlex
Has thanked: 12 times
Been thanked: 5 times
Wed Apr 04, 2018 11:12 am
For the WISP Switches, is there a way to Restore config from a text file? I have tried changing file extension from .txt to .ncfg and using the GUI to Restore, no luck. Have also tried via CLI, but I get a lot of 'ambiguous command' errors.
Thanks.
Re: Restore Config from text file
Wed Apr 04, 2018 11:45 am
The config is stored in a JSON format.
If your file is not exactly and properly formatted it will cause major issues.
Be very very careful.
qlex
Fri Apr 06, 2018 11:51 am
Thanks, Chris. Do you have a suggestion of how best to backup configurations from production switches? I'm hoping to automate this with a platform like Unimus.
Fri Apr 06, 2018 11:54 am
You can use the autobackup option in the device tab that need a TFTP server.
jakematic
Has thanked: 362 times
Been thanked: 87 times
Fri Apr 06, 2018 11:59 am
Or use Netonix Manager - it will auto backup the configs, and then back them up every time you hit Save/Apply.
Lots of other nice features too like scheduling reboots and firmware updates.
viewtopic.php?f=6&t=1549
