I am trying to program some switches using the command line "config" mode but it seems to be missing some ways of setting a few things.
I have not been able to set LAG Aggregation Modes or turn on the discovery tab.
Is there something I am missing or is it just not in there?
command line configuration
- justech
- justech
Re: command line configuration
Also, interface port 1-12 does not alter ports 1-12, only the first port in the range. This is 1.4.9 btw.
Eric Stern - Employee
- Been thanked: 130 times
justech wrote:I am trying to program some switches using the command line "config" mode but it seems to be missing some ways of setting a few things.
You are correct, there are a few things missing from the CLI.
justech wrote:Also, interface port 1-12 does not alter ports 1-12, only the first port in the range. This is 1.4.9 btw.
You cannot specify a port range. When you hit ? and it shows "<1-14>", it is showing you the range of valid port numbers, not suggesting that you are allowed to specify a range of ports.
- justech
Eric Stern wrote:justech wrote:I am trying to program some switches using the command line "config" mode but it seems to be missing some ways of setting a few things.
When can the LAG settings get added? The discovery tab thing is very minor but the LAG stuff is important.
Users browsing this forum: No registered users and 110 guests
