Error saving configuration!
dhoetzel
Mon Mar 05, 2018 3:48 pm
Hi everybody,
we got a problem. We just want to enable one Port but the Switch does not save the config. So what we have to do?
Any possibility over ssh?
Some infos:
WS-24-400A
Firmware Version1.4.7Board RevD
Log:
Mar 5 20:41:22 UI: Configuration changed by admin (10.1.4.1)
Mar 5 20:41:22 UI: Port 10 Enable: changed from 'Disabled' to 'Enabled'
Mar 5 20:41:22 kernel: mini_fo: create_sto_file: ERROR creating sto file.
Thanks for help :hurray:
Julian
Re: Error saving configuration!
Mon Mar 05, 2018 4:08 pm
can be done in CLI - ? <enter> launches context sensitive help.
Failing that, try a factory reset and set it back up, I think there may be something up with your config at the moment- not sure though.
dhoetzel
Mon Mar 05, 2018 5:03 pm
good idea but the switch has no more space left to save the config :/
Maybe after a reboot?
Thanks! :)
Switch(port 10)# no shutdown
Switch(port 10)# exit
Switch(config)# exit
% Applying configuration...
json_object_to_file: error opening file config.json.new: No space left on device
cp: can't create 'config.json.working': No space left on device
Warning: file_put_contents(config.json.new): failed to open stream: No space left on device in /www/config.php on line 752
Warning: rename(config.json.new,config.json): No space left on device in /www/config.php on line 756
Press ENTER to confirm configuration change. If you do not hit enter within 60 seconds the switch will revert to the previous configuration.
Been thanked: 1362 times
Mon Mar 05, 2018 5:23 pm
dhoetzel wrote:Hi,
Thanks! :)
Do not export/save and then import the config because if there is a corruption in the config file like Julian suggested you will export it then import it and still have the config corruption.
Factory default it then manually set the switch back up.
matthew
Re: Error saving configuration! HELP Please..
Tue May 16, 2023 2:52 am
I've have just experienced this problem with firmware 1.5.14 on WS-26-500-DC switch, and the same issue on the 12-250-DC, this is the reason a purchased a new 26-500-DC . New configuration.. after a while saving the configuration it throws this error. Is there a way of fixing without rebooting the switch?
this is the error..
Warning: file_put_contents(config.json.new): failed to open stream: No space left on device in /www/config.php on line 776
Warning: rename(config.json.new,config.json): No space left on device in /www/config.php on line 780
mtdblock6 - jffs mount is full on other switches only 812k used
jffs file list shows only 943k - where is the other data?
matthew
Sat Jul 22, 2023 12:15 am
I seen the same problem. I've done a reset ... factory .. setup switch again. Over time it runs out of space. every time you save the config the partition fills up and eventually runs out of space... just depends on how many changes you make on your switch over time. I power on and off one of my backhauls during peak periods. I've seen this on multiple switches different models same firmware same bug.
Flo
Been thanked: 11 times
Fri Jul 28, 2023 8:13 pm
We had the same issue about two weeks ago on a WS-26-400-AC switch running firmware 1.5.12.
I can confirm that every configuration change (Save/Apply) results in a slight loss of available jffs2 space that is not recovered.
The device affected had an uptime running of about 1.5 years with multiple configuration updates and recovered available jffs2 space after rebooting the device.
Maybe the default jffs2 filesystem has been formatted with less than-needed erase blocks or a running process blocks the outdated, obsolete old configuration: https://linux-mtd.infradead.narkive.com ... filesystem
Would be nice if this issue can be fixed with a firmware upgrade.
