Hello Forum,
I have a remote and hard to reach Netnonix WS-12-250 DC that has become unresponsive after saving/applying its time settings. I have one Sierra RV50 modem that is powered by the switch's POE that I can connect to using the modem's static IP. I'm curious if there is someway to power cycle the Switch using the RV50 or if there is some other integrated software on the Switch proper that might eventually reboot the device. Making a physical trip to the switch at this moment would be very expensive and a last resort.
Thanks again,
AMK
Alternate ways to connect to remote Netonix Switch
- Julian
Re: Alternate ways to connect to remote Netonix Switch
is it responding to ssh requests?
Sorry, no hidden way to talk to switch.
HTTP/HTTPS or Telnet/SSH or Console
Julian wrote:is it responding to ssh requests?
Is there a guide on how to test that? I have only tried it's IP in a browser window (and ping IP).
You use a program like PUTTY and use SSH connection to the IP address of the switch.
Can you even ping the switch IP?
I cannot ping the switch.
This symptom started when I enabled NTP, which I had disabled two days ago during a previous trouble shooting process. This switch was set to power down ports based on voltage and time of day. Do you think it's possible it may be powering all the POE ports and not running the power saving criteria? If that's the case, a site visit will be higher on the list.
Have you ever seen a Netonix switch brick on network but power all the POE ports? I ran a UBNT Discovery from another radio and don't see any other device up there so that sort of leads me to think the switch isn't POEing.
Thanks again,
AK
Thanks again,
AK
I have no idea?
I hope you were running v1.4.9 or at least v1.4.8 as there were warnings about upgrading SMART DC switches to v1.4.8 in the release notes.
You could have a power issue?
You could have damage at the site?
You could have a failed unit?
Or none of the above and something else?
Could be many different issues
Okay right. Guessing games are always fun.
The switch actually just woke up and I'm back in. It's running 1.4.8rc12. While it was down I updated our other one to the 1.4.9 (because it's easy to drive to). I'm very tempted to update the remote switch too, but also hesitant as if it doesn't come back up, I'm gonna bork myself.
amk wrote:Okay right. Guessing games are always fun.
Your call, but if you feel better scheduled a visit as soon as possible and upgrade on site.
Can I send you the logs from the event for comment?
It all started with this (Time stamp is not correct):
Jan 2 11:23:52 UI: NTP_Enable: changed from 'Disabled' to 'Enabled'
Jan 2 11:24:01 system: starting ntpclient
Users browsing this forum: Baidu [Spider] and 83 guests
