firewall settings
- chrisg
firewall settings
I am looking for some firewall settings for the Netonix switch for a Mikrotik board. Need to allow the Netonix switch which is set at 192.168.1.22 and setting it as a NAT rule on Mikrotik as dstnat, protocol 6 (tcp), dst port 8081
Re: firewall settings
OK so there is nothing that needs setup on the Netonix switch.
If the Switch is on an invalid IP inside a NAT on the MT then you need to setup port mapping on the MT to point to the switch. This really is not a firewall setup but rather a port mapping on the MT to point an outside port # to an inside IP port number.
Now you can further setup a firewall rule on the MT so that only you can use the port mapping on the MT NAT which I suggest.
Users browsing this forum: Baidu [Spider] and 77 guests
