HIBERNATE AND WAKE UP VOLTAGE FOR A NETONIX WS-12-250-DC
- Hippolyte MOFFO
hello we are currently using Netonix switches WS-26-500-DC and WS-12-250-DC connected directly to 2x12volt GEL batteries charged by Tycoon UPS TP-BC24-300. we will like to know in case of AC power failure how does the switch detect that batteries voltage is low and hibernates; how will it detect when the batteries are charged and come back on. we will also like to know if it is possible to set the hibernate voltage and wakeup voltage.
Re: HIBERNATE AND WAKE UP VOLTAGE FOR A NETONIX WS-12-250-DC
Read these posts then ask your question again please:
viewtopic.php?f=14&t=3371&p=22205&hilit=+smart+battery#p22205
viewtopic.php?f=34&t=3356&p=22127&hilit=+smart+battery#p22127
viewtopic.php?f=17&t=3378&p=22247&hilit=+smart+battery#p22247
viewtopic.php?f=17&t=3378&p=22255&hilit=+smart+battery#p22255
viewtopic.php?f=8&t=3402&p=22325&hilit=+smart+battery#p22325
viewtopic.php?f=6&t=3352&p=22110&hilit=+smart+battery#p22110
viewtopic.php?f=6&t=3130&p=20964&hilit=+hibernate#p20964
viewtopic.php?f=6&t=2461&p=19277&hilit=+hibernate#p19277
viewtopic.php?f=6&t=2708&p=18815&hilit=+hibernate#p18815
The SMART DC switch when connected DIRECTLY to the battery bank monitors the input voltage which allows you to configure all sorts of things on the POWER TAB
MAKE SURE YOUR USING FIRMWARE v1.4.9
