Firmware Update and Power Loss, Console Recovery, Errors
Chris@edgarhighspeed.com
Has thanked: 4 times
Been thanked: 10 times
Mon Jan 15, 2018 4:50 pm
I was upgrading this switch to latest firmware, bumped the power cable now I'm here.
Hooked up a Null Cable, got the below. Maybe I missed something but when I ran trough the steps.
I didn't get the RedBoot? prompt, only admin@Netonix_Switch:/#
I know I can RMA it but I was hoping to install this switch tonight during a planned outage. Any help would be great,
+M25PXX : Init device with JEDEC ID 0x202018.
Luton26 board detected (VSC7425 Rev. D).
== Executing boot script in 5.000 seconds - enter ^C to abort
RedBoot> fis load -d linux_recovery
Image loaded from 0x80100000-0x8035016c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #6 Wed Sep 17 23:49:
40 EDT 2014
Determined physical RAM map:
Zone PFN ranges:
Normal 0 -> 32768
0: 0 -> 32768
Writing ErrCtl register=80014010
Readback ErrCtl register=80014010
Memory: 126308k/131072k available (1854k kernel code, 4644k reserved, 404k data,
112k init, 0k highmem)
net_namespace: 324 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
mtd: partition "rootfs_recovery" set to be root filesystem
TCP cubic registered
Freeing unused kernel memory: 112k freed
- preinit -
Press CTRL-C for failsafe
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. vtss_core: module license '(c) Vite
sse Semiconductor Inc.' taints kernel.
vtss_core: Unknown parameter `netonix_2_bit_sgpio'
vtss_ioctl: Unknown symbol vtss_dev_all_event_enable
vtss_ioctl: Unknown symbol vtss_uc_flood_members_get
vtss_ioctl: Unknown symbol vtss_phy_power_conf_set
vtss_ioctl: Unknown symbol vtss_mac_table_add
vtss_ioctl: Unknown symbol vtss_qce_init
vtss_ioctl: Unknown symbol vtss_port_map_set
vtss_ioctl: Unknown symbol vtss_ipv6_mc_ctrl_flood_set
vtss_ioctl: Unknown symbol vtss_phy_eee_ena
vtss_ioctl: Unknown symbol vtss_synce_clock_out_set
vtss_ioctl: Unknown symbol vtss_packet_tx_hdr_compile
vtss_ioctl: Unknown symbol vtss_ace_init
vtss_ioctl: Unknown symbol vtss_ace_counter_clear
vtss_ioctl: Unknown symbol vtss_port_conf_set
vtss_ioctl: Unknown symbol vtss_phy_status_get
vtss_ioctl: Unknown symbol vtss_phy_event_enable_get
vtss_ioctl: Unknown symbol vtss_qos_port_conf_get
vtss_ioctl: Unknown symbol vtss_port_status_get
vtss_ioctl: Unknown symbol vtss_ipv6_mc_flood_members_get
vtss_ioctl: Unknown symbol vtss_packet_rx_port_conf_set
vtss_ioctl: Unknown symbol vtss_qce_add
vtss_ioctl: Unknown symbol vtss_eps_port_conf_get
vtss_ioctl: Unknown symbol vtss_ts_egress_latency_set
vtss_ioctl: Unknown symbol vtss_ipv6_mc_del
vtss_ioctl: Unknown symbol vtss_rx_timestamp_get
vtss_ioctl: Unknown symbol vtss_learn_port_mode_get
vtss_ioctl: Unknown symbol vtss_synce_clock_out_get
vtss_ioctl: Unknown symbol vtss_miim_read
vtss_ioctl: Unknown symbol vtss_mc_flood_members_set
vtss_ioctl: Unknown symbol vtss_ipv6_mc_ctrl_flood_get
vtss_ioctl: Unknown symbol vtss_port_counters_clear
vtss_ioctl: Unknown symbol vtss_vlan_conf_set
vtss_ioctl: Unknown symbol vtss_phy_clock_conf_set
vtss_ioctl: Unknown symbol vtss_gpio_event_poll
vtss_ioctl: Unknown symbol vtss_auth_port_state_set
vtss_ioctl: Unknown symbol vtss_reg_read
vtss_ioctl: Unknown symbol vtss_ipv4_mc_flood_members_get
vtss_ioctl: Unknown symbol vtss_sgpio_read
vtss_ioctl: Unknown symbol vtss_fan_controller_init
vtss_ioctl: Unknown symbol vtss_synce_clock_in_get
vtss_ioctl: Unknown symbol vtss_aggr_port_members_set
vtss_ioctl: Unknown symbol vtss_mac_table_vlan_flush
vtss_ioctl: Unknown symbol vtss_mac_table_age
vtss_ioctl: Unknown symbol vtss_erps_port_state_set
vtss_ioctl: Unknown symbol vtss_temp_sensor_get
vtss_ioctl: Unknown symbol vtss_port_clause_37_control_get
vtss_ioctl: Unknown symbol vtss_phy_read
vtss_ioctl: Unknown symbol vtss_port_state_set
vtss_ioctl: Unknown symbol vtss_phy_reset
vtss_ioctl: Unknown symbol vtss_gpio_event_enable
vtss_ioctl: Unknown symbol vtss_ipv4_mc_add
vtss_ioctl: Unknown symbol vtss_gpio_direction_set
vtss_ioctl: Unknown symbol vtss_sflow_port_conf_set
vtss_ioctl: Unknown symbol vtss_fan_cool_lvl_get
vtss_ioctl: Unknown symbol vtss_packet_rx_frame_get_raw
vtss_ioctl: Unknown symbol vtss_mirror_egress_ports_get
vtss_ioctl: Unknown symbol vtss_ace_counter_get
vtss_ioctl: Unknown symbol vtss_gpio_write
vtss_ioctl: Unknown symbol vtss_qos_conf_set
vtss_ioctl: Unknown symbol vtss_eps_port_selector_get
vtss_ioctl: Unknown symbol vtss_phy_conf_get
vtss_ioctl: Unknown symbol vtss_phy_conf_1g_set
vtss_ioctl: Unknown symbol vtss_phy_event_poll
vtss_ioctl: Unknown symbol vtss_port_basic_counters_get
vtss_ioctl: Unknown symbol vtss_phy_write
vtss_ioctl: Unknown symbol vtss_packet_rx_port_conf_get
vtss_ioctl: Unknown symbol vtss_sgpio_conf_set
vtss_ioctl: Unknown symbol vtss_vlan_port_conf_get
vtss_ioctl: Unknown symbol vtss_vlan_trans_group_get
vtss_ioctl: Unknown symbol vtss_qos_conf_get
vtss_ioctl: Unknown symbol vtss_fan_rotation_get
vtss_ioctl: Unknown symbol vtss_mirror_ingress_ports_get
vtss_ioctl: Unknown symbol vtss_mac_table_get_next
vtss_ioctl: Unknown symbol vtss_packet_tx_hdr_encode
vtss_ioctl: Unknown symbol vtss_vce_add
vtss_ioctl: Unknown symbol vtss_timestamp_age
vtss_ioctl: Unknown symbol vtss_ts_freq_offset_get
vtss_ioctl: Unknown symbol vtss_phy_write_masked
vtss_ioctl: Unknown symbol vtss_packet_dma_conf_set
vtss_ioctl: Unknown symbol vtss_dev_all_event_poll
vtss_ioctl: Unknown symbol vtss_isolated_vlan_set
vtss_ioctl: Unknown symbol vtss_tx_timestamp_update
vtss_ioctl: Unknown symbol vtss_phy_veriphy_start
vtss_ioctl: Unknown symbol vtss_miim_write
vtss_ioctl: Unknown symbol vtss_eps_port_conf_set
vtss_ioctl: Unknown symbol vtss_npi_conf_set
vtss_ioctl: Unknown symbol vtss_packet_port_filter_get
vtss_ioctl: Unknown symbol vtss_packet_tx_frame_port_vlan
vtss_ioctl: Unknown symbol vtss_acl_port_counter_clear
vtss_ioctl: Unknown symbol vtss_packet_tx_frame_vlan
vtss_ioctl: Unknown symbol vtss_stp_port_state_set
vtss_ioctl: Unknown symbol vtss_sgpio_event_poll
vtss_ioctl: Unknown symbol vtss_ts_timeofday_get
vtss_ioctl: Unknown symbol vtss_phy_conf_1g_get
vtss_ioctl: Unknown symbol vtss_chip_id_get
vtss_ioctl: Unknown symbol vtss_phy_chip_temp_get
vtss_ioctl: Unknown symbol vtss_mstp_port_msti_state_set
vtss_ioctl: Unknown symbol vtss_ts_timeofday_set
vtss_ioctl: Unknown symbol vtss_eee_port_state_set
vtss_ioctl: Unknown symbol vtss_reg_write
vtss_ioctl: Unknown symbol vtss_phy_led_intensity_set
vtss_ioctl: Unknown symbol vtss_ts_adjtimer_get
vtss_ioctl: Unknown symbol vtss_mirror_cpu_ingress_get
vtss_ioctl: Unknown symbol vtss_aggr_port_members_get
vtss_ioctl: Unknown symbol vtss_phy_enhanced_led_control_init
vtss_ioctl: Unknown symbol vtss_packet_frame_filter
vtss_ioctl: Unknown symbol vtss_ts_ingress_latency_set
vtss_ioctl: Unknown symbol vtss_port_forward_state_set
vtss_ioctl: Unknown symbol vtss_port_forward_state_get
vtss_ioctl: Unknown symbol vtss_restart_conf_set
vtss_ioctl: Unknown symbol vtss_qce_del
vtss_ioctl: Unknown symbol vtss_phy_veriphy_get
vtss_ioctl: Unknown symbol vtss_reg_write_masked
vtss_ioctl: Unknown symbol vtss_mirror_cpu_ingress_set
vtss_ioctl: Unknown symbol vtss_sgpio_conf_get
vtss_ioctl: Unknown symbol vtss_acl_policer_conf_get
vtss_ioctl: Unknown symbol vtss_aggr_mode_set
vtss_ioctl: Unknown symbol vtss_ipv4_mc_del
vtss_ioctl: Unknown symbol vtss_isolated_vlan_get
vtss_ioctl: Unknown symbol vtss_mac_table_port_flush
vtss_ioctl: Unknown symbol vtss_ts_external_clock_mode_set
vtss_ioctl: Unknown symbol vtss_phy_write_masked_page
vtss_ioctl: Unknown symbol vtss_vlan_trans_group_to_port_get
vtss_ioctl: Unknown symbol vtss_pvlan_port_members_get
vtss_ioctl: Unknown symbol vtss_vlan_conf_get
vtss_ioctl: Unknown symbol vtss_mirror_cpu_egress_set
vtss_ioctl: Unknown symbol vtss_phy_power_conf_get
vtss_ioctl: Unknown symbol vtss_phy_mmd_read
vtss_ioctl: Unknown symbol vtss_acl_port_conf_set
vtss_ioctl: Unknown symbol vtss_ts_external_clock_mode_get
vtss_ioctl: Unknown symbol vtss_mstp_vlan_msti_set
vtss_ioctl: Unknown symbol vtss_eee_port_conf_set
vtss_ioctl: Unknown symbol vtss_restart_conf_get
vtss_ioctl: Unknown symbol vtss_ts_adjtimer_set
vtss_ioctl: Unknown symbol vtss_phy_event_enable_set
vtss_ioctl: Unknown symbol vtss_ts_p2p_delay_get
vtss_ioctl: Unknown symbol vtss_ace_add
vtss_ioctl: Unknown symbol vtss_isolated_port_members_set
vtss_ioctl: Unknown symbol vtss_mirror_monitor_port_set
vtss_ioctl: Unknown symbol vtss_ipv6_mc_flood_members_set
vtss_ioctl: Unknown symbol vtss_mac_table_del
vtss_ioctl: Unknown symbol vtss_vlan_trans_group_del
vtss_ioctl: Unknown symbol vtss_ace_del
vtss_ioctl: Unknown symbol vtss_packet_port_info_init
vtss_ioctl: Unknown symbol vtss_packet_dma_conf_get
vtss_ioctl: Unknown symbol vtss_erps_vlan_member_set
vtss_ioctl: Unknown symbol vtss_uc_flood_members_set
vtss_ioctl: Unknown symbol vtss_vlan_trans_group_add
vtss_ioctl: Unknown symbol vtss_phy_led_mode_set
vtss_ioctl: Unknown symbol vtss_phy_coma_mode_disable
vtss_ioctl: Unknown symbol vtss_isolated_port_members_get
vtss_ioctl: Unknown symbol vtss_vlan_trans_group_to_port_set
vtss_ioctl: Unknown symbol vtss_ipv4_mc_flood_members_set
vtss_ioctl: Unknown symbol vtss_vce_init
vtss_ioctl: Unknown symbol vtss_learn_port_mode_set
vtss_ioctl: Unknown symbol vtss_packet_rx_conf_set
vtss_ioctl: Unknown symbol vtss_acl_port_counter_get
vtss_ioctl: Unknown symbol vtss_port_counters_update
vtss_ioctl: Unknown symbol vtss_npi_conf_get
vtss_ioctl: Unknown symbol vtss_phy_mmd_write
vtss_ioctl: Unknown symbol vtss_mirror_monitor_port_get
vtss_ioctl: Unknown symbol vtss_packet_dma_offset
vtss_ioctl: Unknown symbol vtss_mirror_egress_ports_set
vtss_ioctl: Unknown symbol vtss_mac_table_flush
vtss_ioctl: Unknown symbol vtss_phy_status_1g_get
vtss_ioctl: Unknown symbol vtss_vlan_port_conf_set
vtss_ioctl: Unknown symbol vtss_mc_flood_members_get
vtss_ioctl: Unknown symbol vtss_restart_status_get
vtss_ioctl: Unknown symbol vtss_gpio_mode_set
vtss_ioctl: Unknown symbol vtss_mstp_vlan_msti_get
vtss_ioctl: Unknown symbol vtss_temp_sensor_init
vtss_ioctl: Unknown symbol vtss_erps_port_state_get
vtss_ioctl: Unknown symbol vtss_mac_table_vlan_age
vtss_ioctl: Unknown symbol vtss_sgpio_event_enable
vtss_ioctl: Unknown symbol vtss_port_counters_get
vtss_ioctl: Unknown symbol vtss_packet_rx_hdr_decode
vtss_ioctl: Unknown symbol vtss_mac_table_age_time_set
vtss_ioctl: Unknown symbol vtss_ptp_event_poll
vtss_ioctl: Unknown symbol vtss_mstp_port_msti_state_get
vtss_ioctl: Unknown symbol vtss_ts_adjtimer_one_sec
vtss_ioctl: Unknown symbol vtss_vlan_port_members_get
vtss_ioctl: Unknown symbol vtss_acl_port_conf_get
vtss_ioctl: Unknown symbol vtss_auth_port_state_get
vtss_ioctl: Unknown symbol vtss_qos_port_conf_set
vtss_ioctl: Unknown symbol vtss_ipv6_mc_add
vtss_ioctl: Unknown symbol vtss_mac_table_vlan_port_flush
vtss_ioctl: Unknown symbol vtss_acl_policer_conf_set
vtss_ioctl: Unknown symbol vtss_phy_power_status_get
vtss_ioctl: Unknown symbol vtss_fan_cool_lvl_set
vtss_ioctl: Unknown symbol vtss_port_conf_get
vtss_ioctl: Unknown symbol vtss_mac_table_age_time_get
vtss_ioctl: Unknown symbol vtss_mirror_cpu_egress_get
vtss_ioctl: Unknown symbol vtss_ts_operation_mode_set
vtss_ioctl: Unknown symbol vtss_synce_clock_in_set
vtss_ioctl: Unknown symbol vtss_pvlan_port_members_set
vtss_ioctl: Unknown symbol vtss_debug_info_print
vtss_ioctl: Unknown symbol vtss_erps_vlan_member_get
vtss_ioctl: Unknown symbol vtss_phy_pre_reset
vtss_ioctl: Unknown symbol vtss_ts_operation_mode_get
vtss_ioctl: Unknown symbol vtss_phy_chip_temp_init
vtss_ioctl: Unknown symbol vtss_gpio_read
vtss_ioctl: Unknown symbol vtss_mirror_ingress_ports_set
vtss_ioctl: Unknown symbol vtss_eps_port_selector_set
vtss_ioctl: Unknown symbol vtss_port_clause_37_control_set
vtss_ioctl: Unknown symbol vtss_ptp_event_enable
vtss_ioctl: Unknown symbol vtss_stp_port_state_get
vtss_ioctl: Unknown symbol vtss_phy_post_reset
vtss_ioctl: Unknown symbol vtss_vce_del
vtss_ioctl: Unknown symbol vtss_sflow_port_conf_get
vtss_ioctl: Unknown symbol vtss_aggr_mode_get
vtss_ioctl: Unknown symbol vtss_ts_egress_latency_get
vtss_ioctl: Unknown symbol vtss_phy_conf_set
vtss_ioctl: Unknown symbol vtss_rx_master_timestamp_get
vtss_ioctl: Unknown symbol vtss_poll_1sec
vtss_ioctl: Unknown symbol vtss_port_map_get
vtss_ioctl: Unknown symbol vtss_packet_rx_frame_discard
vtss_ioctl: Unknown symbol vtss_eee_port_counter_get
vtss_ioctl: Unknown symbol vtss_ts_p2p_delay_set
vtss_ioctl: Unknown symbol vtss_vlan_port_members_set
vtss_ioctl: Unknown symbol vtss_packet_tx_info_init
vtss_ioctl: Unknown symbol vtss_packet_rx_conf_get
vtss_ioctl: Unknown symbol vtss_ts_ingress_latency_get
vtss_ioctl: Unknown symbol vtss_mac_table_status_get
vtss_ioctl: Unknown symbol vtss_port_state_get
vtss_port: Unknown symbol vtss_port_map_set
vtss_port: Unknown symbol vtss_port_conf_set
vtss_port: Unknown symbol vtss_port_status_get
vtss_port: Unknown symbol port_custom_table
vtss_port: Unknown symbol port_custom_conf
vtss_port: Unknown symbol vtss_port_state_set
vtss_port: Unknown symbol vtss_phy_reset
vtss_port: Unknown symbol port_custom_led_init
vtss_port: Unknown symbol vtss_intr_cfg
vtss_port: Unknown symbol vtss_phy_event_poll
vtss_port: Unknown symbol vtss_stp_port_state_set
vtss_port: Unknown symbol vtss_board_name
vtss_port: Unknown symbol vtss_mac_table_port_flush
vtss_port: Unknown symbol post_port_custom_reset
vtss_port: Unknown symbol port_custom_led_update
vtss_port: Unknown symbol port_custom_init
vtss_port: Unknown symbol vtss_phy_event_enable_set
vtss_port: Unknown symbol port_custom_reset
vtss_port: Unknown symbol vtss_gpio_mode_set
vtss_port: Unknown symbol switch_proc_dir
vtss_port: Unknown symbol vtss_port_counters_get
vtss_port: Unknown symbol vtss_board_type
vtss_port: Unknown symbol vtss_port_clause_37_control_set
vtss_port: Unknown symbol vtss_phy_conf_set
vtss_ethdrv: Unknown symbol vtss_fdma_uninit
vtss_ethdrv: Unknown symbol vtss_fdma_xtr_hdr_decode
vtss_ethdrv: Unknown symbol vtss_mac_table_del
vtss_ethdrv: Unknown symbol vtss_packet_rx_conf_set
vtss_ethdrv: Unknown symbol vtss_fdma_irq_handler
vtss_ethdrv: Unknown symbol vtss_fdma_ch_cfg
vtss_ethdrv: Unknown symbol vtss_fdma_inj
vtss_ethdrv: Unknown symbol vtss_fdma_init
vtss_ethdrv: Unknown symbol vtss_packet_rx_conf_get
i2c /dev entries driver
mini_fo_lookup: ERROR, meta data corruption detected.
mini_fo_d_delete: negative dentry passed.
mini_fo_d_release: no private data.
BusyBox v1.11.2 (2014-09-17 17:18:08 EDT) built-in shell (ash)
Eric Stern
Been thanked: 130 times
Re: Firmware Update and Power Loss, Console Recovery, Errors
Mon Jan 15, 2018 5:02 pm
Somehow you are already at the command line. Just start with the "cd /tmp" step.
Mon Jan 15, 2018 5:03 pm
trying now
Mon Jan 15, 2018 6:14 pm
I think there is something else wrong with this switch,m power light keeps blinking and unlike the other WS-12-250AC's I have the fans don't turn on at startup.
Users browsing this forum: Baidu [Spider] and 85 guests
