Poe 48 or 24 v and 12V ?
quadra
Has thanked: 3 times
Wed Dec 27, 2017 2:34 pm
Hello
I use several devices in 12 volts unfortunately they are not in 48 V POE.
if i would like to use the 12 V of a pair on netonix switch mode on 24 volts 48 V
how can we do? :screwb:
Thank you for your advice
and what is the risk? :yikes:
Re: Poe 48 or 24 v and 12V ?
Wed Dec 27, 2017 2:46 pm
What device needs 12V and does it want it on the ethernet pins or on a barrel connector? How many watts? There are devices on the market that will provide either downconverted from 48V.
Anyway, you posted this question to the wrong place.. It says at the top of the page, PLEASE DO NOT POST QUESTIONS HERE!
EDIT: I see this got moved.
jakematic
Has thanked: 362 times
Been thanked: 87 times
Wed Dec 27, 2017 5:52 pm
lligetfa wrote:There are devices on the market that will provide either downconverted from 48V.
One such device: https://www.streakwave.com/itemdesc.asp ... =&Tp=&o1=0
Another such device: https://www.poetexas.com/collections/al ... poe-12v10w
