Copper SFPs Doing Odd Things
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Thu Dec 21, 2017 11:09 am
So I've noticed something now across all of my switches. If the copper SFPs in the SFP ports get disturbed in anyway (and it might even be pulling the Ethernet cable out and plugging it back in), the entire SFP has to be reseated (or the switch rebooted) in order to get the interface to come back up.
Is this a known issue, or any further troubleshooting steps I can take?
Re: Copper SFPs Doing Odd Things
Thu Dec 21, 2017 11:34 am
Here are a few post where I discussed this issue in the past.
I too have found some SFP modules that do this same behavior.
I test SFP modules in LAB before I deploy them.
viewtopic.php?f=7&t=2849&p=19636&hilit=+sfp+insert#p19636
viewtopic.php?f=17&t=2749&p=19032&hilit=+sfp+insert#p19032
viewtopic.php?f=17&t=302&p=17833&hilit=+sfp+insert#p17833
My suggested test procedure:
Put suspect SFP in switch
Plug laptop into it
log into switch and do a warm reboot from the UI
Plug and unplug my laptop several times
If it did not mess up until this point then your fine.
As a note I have found 1 out if X SFP modules all the same that would not properly work in my switch.
Meaning I bought 10 of the same yet found 1 in the batch that did not pass the above tests
Townsendkey
Has thanked: 6 times
Mon Jan 08, 2018 6:07 am
Used to meet this problem like you too, the copper SFP was bought online.
Fortunately, their tech support help me solve this problem, it's just because my switch do not support sfp module with LOS. ( ̄. ̄)
Check your device to see if you make the same mistake with me. Haha
mhoppes
Mon Jan 08, 2018 11:48 am
LOS? What is LOS?
