Having issues connecting Netonix to Cisco switch
dcshelp
Wed Dec 13, 2017 10:52 am
I'm getting the an error when connecting a ws-8-150-dc to a cisco 3560 switch via fiber. The interface constantly goes up and down. Have some screenshots below. I am running the latest firmware from netonix.
Netonix Switch
https://imgur.com/iO50ZPt
Cisco 3650
https://imgur.com/YlVZf1c
Julian
Re: Having issues connecting Netonix to Cisco switch
Wed Dec 13, 2017 11:32 am
What version of firmware are you using?
dcshelp
Wed Dec 13, 2017 11:33 am
Using 1.4.8
Julian
Wed Dec 13, 2017 11:55 am
Seems like something with QinQ - check out https://supportforums.cisco.com/t5/lan- ... d-p/638763 , seems like you're not the only one who's seen this.
Can't really provide support on Cisco's stuff, but hopefully that gets you on your way
Wed Dec 13, 2017 12:43 pm
You could try without STP. You could test with all vlan tagged on the Netonix's port facing the Cisco or with native vlan untag.
If Stiller happening, I would also test to disable the STP on the Netonix.
